Photoresist developer
Discussion in 'General Electronics Chat' started by sirket, Mar 7, 2009.
Thread Status:
Not open for further replies.
  1. sirket
    Mar 7, 2009
    11
    I'm loathe to use straight NaOH or KOH as a developer because I would prefer to have a buffer when developing. As I want to be able to use this in a spray etcher I am building, a buffer would be really helpful.
    I've never been able to find silicate developer solution so that leaves me with making it as the only alternative (and that's fine- I'd prefer to understand what's going on anyway). That said- can anyone explain the chemical processes at work during developing?
    I've read the Moorshead recipe but without understanding what does what- it just seems arbitrary. It seems like a regular NaOH developer with sodium silicate as a buffer and nothing else. Is it that simple? The silica developer sold by Rapid Electronics does not contain NaOH so I suspect it's a very different animal.
    Any help would be appreciated.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Welcome to the forum.
    The OP for this thread has not been back in awhile. It would probably be best for you to start a new thread on the exact subject that concerns you.
    I agree that on the surface, using a buffer has certain appeal for maintaining consistency. It also appears that different formulations of photoresist require different developers. For example, I use Injectorall. It is orange, not green. As a developer, I use 0.4 M KOH. There is quite a window in time (several minutes) between under development and over development.
    I have tried several silicate recipes, and could not get any of them to work. The reason is simply that the conjugate acid of even silicates is too strong. Thus, any pH at which there is buffering capacity is insufficient to develop the Injectorall photoresist.
    To move forward, you need to know more about the photoresist you are using. Can it be developed in a silicate buffer? Can you think of any other acid that is sufficiently weak to give buffering at the pH needed to develop your brand of board? I considered some of the organic alcohols (e.g., methanol), but did not pursue it as the alcohol might soften the photoresist. Of course, I suspect you want to stay away from oxides of heavy metals too.
    John
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. sirket
    Mar 7, 2009
    11
    Deleted for clarity.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    I think you ignored my statement that the chemistry of the different resists is somewhat different. Try the Moorshead formula. If it works for you, use it. I don't see how you can dismiss something like that without knowing details of the chemistry of the resist you are using, which I suspect you do not know. This is not a theoretical discussion.
    What else are you looking for? Can you suggest another buffer to use?
    John
  6. sirket
    Mar 7, 2009
    11
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    1) They are different colors.
    2) They differ in photosensitivity based on user reports on this forum.
    3) They differ in developer sensitivity. Some can be devoloped with carbonate buffers; others require sodium or potassium hydroxides.
    4) Check out this link for a brief review of Novolak resins. Some produce carboxylic acids, which implies greater sensitivty of basic developers than those that produce phenolic residues.
    I am not sure what you are trying to say. It either works or it doesn't.
    The general reactions are well known. Apparently, you want proprietary information, which you are not likely to get.
    Apparently you don't understand fundamental acid-base chemistry.
    Money? I suspect it will not work with Injectorall, unless it is more alkaline than sodium silicate, i.e., has KOH of NaOH.
    You seem confused between the etching process and the developing process. How much experience do you have with either?
    Read up on silicates. You will find it is complex and in general, there is no way to answer that question.
    What's the difference?
    Why don't you call the manufacturer and ask it for the details? Say I sent you. You still won't get them.
    John
  8. sirket
    Mar 7, 2009
    11
  9. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    A modicum of civility is called for here. We are discussing technical matters, not trading flames. This is your one and only warning.
  10. sirket
    Mar 7, 2009
    11
    Moderators: Can you please delete this thread- It's devoid of technical information and of no value to the forum community. I'll start another post when I have more useful information to share.
Thread Status:
