Photography Safe Light-Photo Resist method
Discussion in 'The Projects Forum' started by JDR04, Dec 19, 2014.
  1. JDR04
    Thread Starter Active Member
    May 5, 2011
    339
    Hello all. I'm planning to start using the photo resist method of generating PCB's.
    Would I be able to work with a darkroom safelight? I've read that one has to prevent any daylight at all so I am a bit wary of having to work with boards etc in total darkness.
    Any help or suggestions will be appreciated. Thanks a lot.......JDR04
  2. Dodgydave
    Jun 22, 2012
    5,159
    772
    red lights are used as safety lighting.
  3. #12
    Nov 30, 2010
    16,705
    7,354
    The photo-resist boards I used only responded to UV wavelengths, and they needed 20 minutes in direct sunlight. I think you got some bad information. Why would anybody make a photo-resist board that is as sensitive as normal camera film??? Not for hobbyists!
  4. MrChips
    Oct 2, 2009
    12,648
    3,458
    I use a yellow bug light.
  5. JDR04
    May 5, 2011
    339
    THANKS FOR THAT
