photogate scr trigger
Discussion in 'General Electronics Chat' started by Joeshmoe, Apr 29, 2007.
Thread Status:
Not open for further replies.
  1. Joeshmoe
    Thread Starter Active Member
    Jan 12, 2007
    66
  2. mozikluv
    Jan 22, 2004
    1,437
    can you post a schem of what you are trying to do? this way we can clearly direct you to solving your problem.
    moz
  3. Joeshmoe
    Jan 12, 2007
    66
    i hooked up the trigger output to the scr im not sure what kind of schem you want i would like to give you any information you need to help me thanx
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Here's the schematic. I can't for the life of me figure out how this is supposed to work. The load has one side connected to ground and the other side connects through the SCR to ground.:confused:
  5. Joeshmoe
    Jan 12, 2007
    66
    im not sure what your saying but if you tell me what you need i can get it for you
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Where is the schematic? :confused:
  7. Joeshmoe
    Jan 12, 2007
    66
    all the info i have is in the first post theres no schematic but there is something on how the trigger is made
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  9. Ron H
    Apr 14, 2005
    7,050
    657
    This will trigger when the light from the LED is blocked. If you need it to trigger when the the light is not blocked, swap the position of the phototransistor with the 100k/1k series resistor combination.
  10. Joeshmoe
    Jan 12, 2007
    66
    thanx for the schem but it doesn't seem to work... it it is possible that i am not wiring it properly i havent been working with schems like this for that long i am getting inconsistent readings and its just not triggering it
  11. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    http://www.hiviz.com/kits/instructions/images/bb_125.jpg The two-conductor cable is the load. Red connects to the SCR o/p and black connects to ground.
    My question: Once the SCR is triggered, electrons are supposed to flow from ground, through the SCR and the load, and then back to ground?:confused: Does the load contain an independant power source?
  12. Joeshmoe
    Jan 12, 2007
    66
    I did hook it up that way and it didnt work.. i think the problem is that the voltage difference is not large enough (between blocked and not blocked).trigger does have a 9v battery.
  13. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    The trigger circuit has a 9v source, but what about the load? What about the thing that gets triggered? Looks to me like it has both sides connected to ground.:(
  14. Joeshmoe
    Jan 12, 2007
    66
  15. Joeshmoe
    Jan 12, 2007
    66
    i think the problem is that the voltage isnt raising high enough...when the beam is uninterrupted it is at about .3 volts and when interrupted it is about .45 volts
  16. Ron H
    Apr 14, 2005
    7,050
    657
    If you're talking about the gate voltage, you may have too much ambient light on the phototransistor, or you need to adjust the pot, or both.
  17. Joeshmoe
    Jan 12, 2007
    66
Thread Status:
