Photoelectric effect, very high frequencies and lower current
Discussion in 'Physics' started by Robin Mitchell, May 31, 2016.
  1. Robin Mitchell
    Oct 25, 2009
    738
    207
    Hi all,
    Quick question, if you increase the frequency of incoming photons in a photoelectric effect setup would the current rate eventually reduce? My idea is that because the wavelength of the incoming photons becomes much smaller than the size of the atoms and the space between shells the photons would just pass straight through (like in an X-Ray machine)?
    All the best,
    Robin
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Can you put some numbers on what you think the order of magnitude is for the distances and frequencies/wavelengths involved? One thing I know is that as frequencies go up so does the attenuation in any medium you can think of from the vacuum of space to transmission lines to antennas.
  3. Robin Mitchell
    Oct 25, 2009
    738
    207
    I dont have numbers (I know thats really bad), but I got into a convo with someone who asked me why the current goes down as the frequency goes up (after saturation).
    I said that I dont know the real answer but my theory was as thus:
    1. As frequency gets higher, so does the energy of individual photons
    2. Absorption coefficient is inversely proportional to energy
    3. Photoelectric effect is directly proportional to Absorption coefficient (unless high energies are involved which then brings in Compton and pair production)
    4. Therefore photoelectric effect is inversely proportional to frequency after a certain value which is far beyond the work function
  4. crutschow
    Mar 14, 2008
    13,494
    3,373
    The vacuum of space??:confused:
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    So here are some numbers from my experience:
    1. Useful RF propagation is about 1 km @405 GHz (740 μm)
    2. Visible light propagation is about 500' @475 THz (631 nm)
    The scale of an atom is on the order of 0.1 to 0.5 nm. You are talking about something like
    https://en.wikipedia.org/wiki/Very-high-energy_gamma_ray
    Which are at even higher frequencies and energies. They don't appear to be stopped or scattered by very much. Since photons do not appear to have a charge they are not going to respond to a nucleus of charged particles. They do have sufficient energy to knock electrons out of their shells. These electrons will give up that energy, as visible or infrared light, when they return to a lower energy level. IIRC there is nothing about the photoelectric effect that imposes a limit on photon energy and what happens in a solid material when it experiences an impact from high energy photons.
    I haven't really considered Compton scattering or pair production in quite a while so I'll have to do some reading.
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Would you prefer the vacuum of "interstellar space", which actually still has some stuff in it.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    I am interested in the "tuned nano antenna" concept that was floating around a decade or so. Supposedly the efficiency for a specific frequency of light would be through the roof. While I suspect it will get there eventually, we're not there yet.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    How were they fabricated?
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    As I understand it they weren't. It was in concept stage, but the technology is getting better all the time. You make an antenna array, each with a built in diode. If they were transparent at other frequencies it might amount to something, but I am waiting and seeing (a common practice with vaporware).
    Basically ultra fine wafer fab fabrication.
  10. BR-549
    Sep 22, 2013
    2,178
    419
    "I dont have numbers (I know thats really bad), but I got into a convo with someone who asked me why the current goes down as the frequency goes up (after saturation)."
    This effect has nothing to do with frequency. The photo detector simply ran out of charge.
    Are you varying the frequency of the light source?
  11. nsaspook
    Aug 27, 2009
    3,013
    2,357
  12. Robin Mitchell
    Oct 25, 2009
    738
    207
    I am varying the frequency of the incoming photons but please understand that I am not performing a real experiment. My brother used an online app that allows you to vary the different aspects of the setup and when he turned the frequency right up the current dropped.
