Photodiode Signal Conditioning
Discussion in 'The Projects Forum' started by electronicsguy7810, Jan 7, 2016.
  1. electronicsguy7810
    Jan 7, 2016
    For a project, i'm wanting to use a photodiode and a microcontroller to log ambient light levels in my garden.
    I need an op-amp circuit that will output 5v to the microcontroller when ambient light is equivalent to 5mW/cm^2.
    The photodiode I have is TEMD6010FX01
    Below is what I have for a start
    Can anyone advise me on weather this is right, and if so how can I work out what C1 and R1 need to be
    Tim
  2. crutschow
    Mar 14, 2008
    13,527
    3,393
    Need to know the output current of the photodiode at 5mW/cm^2 illumination.
    Do you have a data sheet for it?
  3. electronicsguy7810
    Jan 7, 2016
  4. crutschow
    Mar 14, 2008
    13,527
    3,393
    According to the data sheet the diode has a nominal sensitivity of 1μA per 1mW/cm^2 with a 5V reverse bias.
    It does not give the current with zero bias as your circuit shows.
    So if you apply a 5V reverse bias to the diode anode than a value of 1megΩ for R1 will give a nominal output of 5V for an illumination of 5 mW/cm^2.
    But note that the diode sensitivity tolerance is -25% to +225% so, if you need better accuracy then that, you will need to calibrate the circuit or get a diode with a better sensitivity tolerance.
    electronicsguy7810 and sailorjoe like this.
  5. electronicsguy7810
    Jan 7, 2016
    Thanks for the response!
    Is this what you mean?
  6. crutschow
    Mar 14, 2008
    13,527
    3,393
    That's forward biasing the diode.
    It needs to be -5V.
