Photodiode sensitivity vs distance
Discussion in 'The Projects Forum' started by nacoolp, Jul 11, 2013.
  1. nacoolp
    Jan 2, 2013
    14
    Hello all,
    I am using a rotary laser light transmitter and a photo diode and its filter circuit to detect the former even in the sunlight. Now when I use the same at a distance up to 300 m the detection occurs perfectly. But beyond this distance, the diode hardly detects the light.
    Circuit diagram is given in the pdf file attached for reference.
    Thanks in advance.
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    Do you have a question?
    The answer is optics.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    I think the answer may be that the photodiodes are forward biased, and R1 is much too small. I would reverse the photodiodes, and change R1 to 100k.
  4. wayneh
    Sep 9, 2010
    12,405
    3,256
    Even though it already works fine at 300m ?
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Maybe he can get more output by reversing the diodes, or maybe the diodes are already reversed.
    I don't have a lot of experience with photodiodes, but in the literature, I have never seen a photodiode being used in the forward-biased mode.
  6. nacoolp
    Jan 2, 2013
    14
    Thanks Wayneh Ron H for your feedback.
    And Sorry for a big mistake.
    The photodiodes are used in the reverse biased mode only. By mistake its orientation was reversed.
    Thanks and enlighten me with your view when the diodes are reverse biased.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    What are your frequency response requirements (low and high frequency corners)?
  8. nacoolp
    Jan 2, 2013
    14
    My frequency response requirement is any signal above 3 Hz (to nullify the sunlight).
    I have tried a lot of different combinations for the same but to no avail. Now I am confused which of the following could be the factor responsible for this scenario:
    1) Capacitor C1 (4.7nF) is not discharged completely as with the increasing distance, contact time between laser light and photo diode reduces.
    2) Low gain of transistor as with increasing distance the intensity of light reduces to a certain extent and thereby weakening the signal.
    Thanks and Regards
  9. Ron H
    Apr 14, 2005
    7,050
    657
    1. The charge on the cap should not change appreciably.
    2. I don't understand what you mean.
    The circuit you posted has a low frequency corner of ≈15kHz. To get ≈3Hz, change R1 to 100k and C1 to 470nF.
