photocell
Discussion in 'General Electronics Chat' started by amir ee, Apr 4, 2008.
  1. amir ee
    Apr 4, 2008
    I need professional information about photocell...
    or if you can't help me,please tell me which sensors are suitable to apecify the light beams path?
    Thank you...
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You may be asking about LDR's (light dependent resistors). There are also phototransistors and integrated devices with photodiodes and amplifiers.
    Can you tell us more about your application?
  3. rwmoekoe
    Mar 1, 2007
    172
    do you mean that you want to detect the path of a light beam as to which direction it is beaming?
  4. amir ee
    Apr 4, 2008
    a kind of sensors that can be used to measure the light intense and they are suitable to specipy the light beams direction too...
    and YES rwmoekoe!
  5. rwmoekoe
    Mar 1, 2007
    172
    it's a challenging one. can anybody help? or can we brainstorm about this?
  6. rwmoekoe
    Mar 1, 2007
    172
    will it matter if the degree of direction measured is only - say 90° conical or so, and the light beam will be somewhat reduced going through the device?
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The mechanical design could get elaborate, but making an array of photosensors with limited lines of sight can be done. Going beyond eight might get expensive.
    It should also be possible to arrange a spinning photosensor with something like a servo pot or position encoder to indicate the direction light was coming from.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Going a bit further with beenthere's concept...
    Consider a phototransistor mounted on the edge of a spinning disk. If that spinning disk were mounted on the edge of another disk slowly rotating disk, slightly less than the diameter of the first disk, the path of the single phototransistor would be much like that of a Spirograph design.
    http://en.wikipedia.org/wiki/Spirograph
    Adjusting the relative speeds of the two disks could give very complete coverage of the swept area. The position of the reading could be interpolated from the reported positions of the two disks.
    This concept would require a somewhat complex slip-ring arrangement for the phototransistor, motors, and position encoders' signals.
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Or you could arrange to sweep 360 degrees clockwise and then 360 degrees counterclockwise and repeat - no slip rings needed.
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Yes, that's a definite possibility - or just 180° either way, for both sweeps - or perhaps even less. Some of that would be dependent on the OP's need for speed of acquisition, as naturally it will take time to deaccelerate, reverse direction and accelerate the sensor. There are potentially a great many data points to be taken and compared.
    It wouldn't be too difficult to complicate this project to the bleeding edge of comprehension. :confused: :D
    However, having the limits of rotation would eliminate some potentially very useful scan patterns such as the hypotrochoid known informally as an 8 leafed rose. There is an animation of this pattern (and many more) near the bottom of this page: http://xahlee.org/SpecialPlaneCurves_dir/Hypotrochoid_dir/hypotrochoid.html
  11. rwmoekoe
    Mar 1, 2007
    172
    wow, great ideas!
    i've just thought about this one,
    the light beam should pass through two partially transparent mirrors consecutively.
    each mirror partially reflect the beam towards their own ccd sensors.
    we can then get the two coordinates from the two ccd's to determine the direction. (and the intensity).
    the drawback is that the light would be filtered twice and thus twice reducing its intensity.
    amir, what do you think about those ideas? i'm curious here :)
