Photo-Transistor Circuit
Discussion in 'The Projects Forum' started by tritechinc, Dec 21, 2015.
  1. tritechinc
    Dec 21, 2015
    Has anyone ever seen a circuit like this before? The emitter is tied to VCC.
    Please note that the diode is a photo-diode, there is an emitter circuit but it is not shown. I am trying to copy a small circuit board from a defective IR receiver. There are no schematics and the company is long gone. I traced out the circuit paths and diode checked the transistor. I do not know the resistor value because that is what failed, I should be able to figure that out doing a little math. (The top blew off so I can not read the code, the entire thing is smt and on a board 2cm x 2cm.)
    Can anyone help me?
  2. ScottWang
    Aug 23, 2012
    4,930
    777
    You didn't showing that how the pins connecting to as RED, BLK, YEL?
  3. tritechinc
    Dec 21, 2015
    Red is VCC (+12vdc), Blk is GND and YEL is the circuit output of which has +12vdc on it. When the circuit operates it should pull YEL to ground. I don't understand why the emitter is tied to VCC, then goes through that resistor to the transistor base. I want to know if this circuit would actually work, if not then I have something wrong. (But I don't think I do)
  4. ScottWang
    Aug 23, 2012
    4,930
    777
    There is no the right opto transistor, so I can't analyze further, the circuit could be like as the right one.
  5. hp1729
    Nov 23, 2015
    2,097
    232
    Wow! given those three parts the most likely configuration (figure G) is the farthest from your findings. :)
  6. tritechinc
    Dec 21, 2015
    hp1729 That is very helpful! Thank you!
  7. tritechinc
    Dec 21, 2015
  8. hp1729
    Nov 23, 2015
    2,097
    232
    Have you considered just putting a voltage on it and see what it does? +5 V to red, ground to back. Tie a pullup resistor from yellow to +V. Shine a light on the sensor (IR TV remote?) and see if the output goes low.
