Photo Resistor question
Discussion in 'General Electronics Chat' started by AlexK, Nov 20, 2007.
  1. AlexK
    Thread Starter Active Member
    May 23, 2007
    34
    My question is this: can I connect a photo resistor in place of a resistor
    and expect the circuit to act the same (for a constant amount of light)?
    For example, in the following circuit:
    http://www.radio-electronics.com/info/circuits/opamp_inverting/op-amp_basic_inv.gif
    If I connect my photo resistor in place of R2 will the gain be equal to -Rp/R1?
    (Where Rp is the resistence of the photo resistor for some constant amount of light)
    Thanks.
  2. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    a resistance is a resistance.
    What you are proposing is commonly used as the variable gain element in an audio compression/limiting/ or AGC circuit, with the LDR optically connected to a LED or light source whose brightness is determined by the audio level. ... ie. sound gets louder, light gets brighter, LDR resistance decreases, gain decreases pulling the audio level back again.
  3. Voltboy
    Jan 10, 2007
    197
    why not using a simple resistor.. less problems
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    A photo resistor is not very accurate and has memory. You should expect the gain to be unstable.
