*PHOTO* Need help- WHAT DIODE IS THIS?
Discussion in 'The Projects Forum' started by bigcape, Sep 22, 2009.
  1. bigcape
    Sep 18, 2009
    158
    I think this diode is bad.
    It meters .0L both ways. However there are no markings can anybody tell?
    I am repairing an analog multi-meter. (attempting that is )
    Thank you for the help!
    here is another
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It could be about any old glass-passivated diode. It's not big enough to be a rectifier. You can always try a 1N914 - good luck figuring where the cathode points.
  3. bigcape
    Sep 18, 2009
    158
    That will be easy because it is printed on the circuit board I took it from!:)
  4. bigcape
    Sep 18, 2009
    158
    It came out of the top right corner
    Why cant you test components soldered in place if you just meter on opposite leads of the component?
    What I was reading about electron flow, the positive and negative leads of the multimter would be the "circuit" right?
  5. studiot
    Nov 9, 2007
    5,005
    515
    Beware of loosing the ball bearing from the switch rack.
  6. salty9
    Jun 8, 2009
    7
    If you don't isolate the circuit component you are also reading the rest of the circuit.
  7. bigcape
    Sep 18, 2009
    158
    No kidding... I dropped once!
    Open yours up and tell me what diode to use!!
    Im going to fix this thing till it's REAL BROKE!
  8. bigcape
    Sep 18, 2009
    158
    I went to two places to see if anything "looked" the same.
    NO LUCK!
    But I ended up buying a HAKKO FX-951 and an 808 desolderer.
    This project is getting expensive.
  9. JoeJester
    Apr 26, 2005
    3,390
    1,211
    What is the model number of your multimeter?
    You might find a schematic on the internet ... or maybe not.
  10. bigcape
    Sep 18, 2009
    158
    Excelent Idea JOE!
  11. bigcape
    Sep 18, 2009
    158
    Funny thing is...... all the links that sound promising take me RIGHT BACK TO THIS SITE!!!!
    oh, no schematic!
  12. JoeJester
    Apr 26, 2005
    3,390
    1,211
    I noticed the sensitivity of that meter was 2k/V. That's going to load down alot of the circuits you'll want to build ... and it could introduce some unwanted results to the circuit.
  13. bigcape
    Sep 18, 2009
    158
    Thank you for the tip.
    This more of a learning experiment. I have a nice Auto-Ranger.
    I'm using this broken meter to teach myself all kinds of stuff.
    Heck, I found my FIRST bad component--- All by my lonesome!
    (with help from all the great reading on this site):D
  14. bigcape
    Sep 18, 2009
    158
    bump! It's been over 1week n 1/2!
  15. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's not worth repairing.
    Get a new one and start over.
  16. bigcape
    Sep 18, 2009
    158
    Who cares? That isn't the point.
    Let's turn it into a contest then..... "Guess the Diode"
  17. t06afre
    May 11, 2009
    5,939
    1,222
    I guess you have "reverse engineer" the PCB back to a schematic. Then we may be able to help.
  18. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Any cheap little signal diode is going to work. If you are concerned about voltage and current, consider the meter isn't much, and you're risking on the order of $.05.
  19. Wendy
    Mar 24, 2008
    20,772
    2,540
    Shoot, I still have a reel of 1N4007 I paid $1 for. What's that, about 1/10¢
  20. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Guess he could try a 1N1186 to play safe. Have to make a hole in the case, though.
