Forest MIMS used Green diodes as light sensors in may projects - all the way back to the 1970s. connect cathode to ground and anode to a large value resistor and the other end of that resistor back to ground. Then measure off of the node between LED and resistor when exposing the Green LED to visible light. Any power should flow from that resistor/LED junction as well. Use the old-school LEDs, not the HB LEDs that have green phosphors on them. You will need UV to penetrate the phosphors and excite the LED diode surface (not efficient).
Remember, the little chip in an LED doesn't have nearly the surface area to capture sunlight that a full panel has. Therefore, power will be greatly reduced. Look at the LED "chip" on a clear LED with a magnifying glass for scale.
