Phone Charging
Discussion in 'General Electronics Chat' started by Michael Nusair, Oct 27, 2015.
  1. Michael Nusair
    Oct 21, 2015
    16
    is there any way to make a usb cable that cuts the power when the phone gets to 100%?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Doesn't your phone do that internally? Every one I have owned since ~ 1980 does.
  3. Michael Nusair
    Oct 21, 2015
    16
    i want to do it in the cable. so that the phone will fell disconnected
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    How will the external circuitry determine the state-of-charge of the internal battery when the battery terminals are not accessable without cutting holes in the cell phone?
  5. Michael Nusair
    Oct 21, 2015
    16
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Many phones flash up a battery full indication - a photo cell could detect that and trip a breaker circuit.
    It would be unwise to tamper with the battery circuitry in any way - most phones use lithium cells, and those can catch fire if the charge control goes wrong.
  7. KMoffett
    Dec 19, 2007
    2,584
    234
    Sounds like a microprocessor (powered continuously by the USB) monitoring an inline current-sensing resistor and a MOSFET to disconnect the power when the charge current level drops.
    Ken
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    It is totally unnecessary. Wonder if it is a scam?
  9. KMoffett
    Dec 19, 2007
    2,584
    234
    Agree!
    kEN
  10. AnalogKid
    Aug 1, 2013
    4,686
    1,297
    Or a comparator (no microcode).
    Or the standard current shunt plus transistor base-emitter junction current sensor driving the series pass transistor. Two transistors, 3 resistors, and one cap, but 0.6 V drop across the sensor. Germanium?
    ak
  11. #12
    Nov 30, 2010
    16,670
    7,314
    This makes about as much sense as adding a hose designed to turn the gas station pump off when my gas tank is full, and attach it to the gas station hose that already does that.o_O
    Sinus23 likes this.
  12. recklessrog
    Member
    May 23, 2013
    346
    102
    ha ha! so true!
