Phone car charger interrupt FM tuner reception
Discussion in 'General Electronics Chat' started by yuvi1, Apr 2, 2013.
  1. yuvi1
    Feb 1, 2013
    37
    Hi guys
    i have a problem in my car.
    when i charge my phone (SAMSUNG GALAXY S2) in my car , i'm getting noise when i listen to the radio , it's sounds like there is a weak reception.
    when i unplug the charger , there is no noise.
    any idea what should i do ?
    what may cause the interference ?
    and how can i fix this ? maby some kind of a filter?
    thanks!
  2. Dodgydave
    Jun 22, 2012
    5,167
    777
    I had this before , its the rf osc causing spurious radiation , i fitted a ferrite ring, it just moved the rf to a different band, maybe it may work for you.
  3. yuvi1
    Feb 1, 2013
    37
    thanks for the information , ill try to fit a ring
    but i have a question for you , where is the rf osc ? you mean the osc from the phone ?
  4. Dodgydave
    Jun 22, 2012
    5,167
    777
    no oscillator on the charger, it will be a mini smps so it will be giving out rf all over the place, try the ferrite ring or it may be that wrapping the circuit in tin foil ( Faraday cage) without shorting out the pcb, and connecting the foil to the supply negative may cure the problem.
    Try and use the charger on an external battery and see if its radiating, if it works ok on a seperate battery , then its feeding back down the supply.
  5. tindel
    Sep 16, 2012
    576
    196
    I agree it's most likely radiated emissions from your charger being a 12V to 5V (probably) switch mode power supply. A harmonic of the switching frequency of the SMPS is probably getting back onto some length of cable, and it's a high enough frequency on a long enough cable that it makes a good antenna that interferes with your local AM or FM bands (or both).
