Phone-Activated Lamp Controller
Discussion in 'Homework Help' started by Point_Man, Feb 22, 2004.
  1. Point_Man
    Feb 22, 2004
    For an assignment, I have to analyze the following circuit:
    http://www.geocities.com/spc_point_man/homework.txt
    (Click here if the above link does not work)
    However, I've been sick the last few classes, and am falling behind. Is there anyone here who can please explain how the current flows through the circuit so I can answer some problems relating to it?
    Ex: 1) Determine the current through R3 when the optocoupler is activated.
    I am lost and really need help. Any help at all is greatly appreciated!
    Thank you in advance! :D
  2. Point_Man
    Feb 22, 2004
    Nevermind - I got it all figured out. :D
  3. Battousai
    Nov 14, 2003
    141
    44
    What is that U1 circuit element? :blink:
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    :huh: I have no idea, it looks like half a diode! :blink:
    Unless its a test point, but I've never seen one drawn like that.
  5. Point_Man
    Feb 22, 2004
    It's called a Shockley Diode... but its not a diode :huh:
    It's more like two BJT's connected together with only two external connections available.
    In essence, this device acts like two cutoff transistors until the voltage across Anode to Cathode exceeds the breakdown voltage VBRF, at which point minority carrier current flowing through one device into the base of the other device turns it on. The second device now turns the first device on, establishing lots of current to keep both devices turned on.
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Ah, so its exactly like a BJT, but with an increased breakdown voltage. Strange device <_<
