Phase Shifts
Discussion in 'Homework Help' started by extremeads1, Feb 17, 2007.
  1. extremeads1
    Thread Starter Active Member
    Feb 10, 2007
    64
    I have been taught and seen that there is a lead of current in a capacitor by 90degrees and lag of current in a inductor by 90 degrees.
    What is the reason behind the phase shifts in these components !
    pls do let me know fast..........
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Read the E-book on this site - Volume 2, chapters 3 & 4.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Essentially its because the current-voltage relationship for capacitors and inductors is of a variable that is dependant on a rate of change of an instantaneous value in the other variable, i.e. for a capacitor i = C(dv/dt) and for an inductor v = L(di/dt); where the derivative expression is the rate of change of an instantaneous value in the other variable.
    For an explanation of the situation for a capacitor see: Volume II - Chapter 4.2
    For an explanation of the situation for an inductor see: Volume II - Chapter 3.2
    Dave
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    That and the following little nuggets
    Code ( (Unknown Language)):
    1.
    2. d(sin(x))/dx = cos(x)
    3.
    4. d(cos(x))/dx = -sin(x)
    5.
    6. so cos(x) = sin(x-90degrees)
    7.
    8. and -sin(x) = cos(x+90degrees)
    9.
    Curious how things unfold
  5. extremeads1
    Feb 10, 2007
    64
    Thanks ,
    for posting the reply ,now I Understood .
