Phase Shift Circuit Oddity
Discussion in 'General Electronics Chat' started by dannybeckett, Aug 7, 2012.
  1. dannybeckett
    Thread Starter Active Member
    Dec 9, 2009
    163
    Hi everyone,
    I am building a lock-in amplifier, of which a quadrature phase shift section is required. I have constructed the circuit here:
    http://www.tedpavlic.com/teaching/os...se_shifter.pdf
    Which does work very nicely. I have chosen 5K1 resistors for the feedback, a 100K trimpot and a 3.3nF capacitor for the RC circuit. This gives me a range of about 500Hz to 100KHz at 90 degrees phase. The problem I am having is that at higher frequencies, the output waveform is somewhat distorted.
    At 1KHz everything is OK:
    http://snag.gy/yfcPO.jpg
    At 80KHz the output waveform is somewhat distorted:
    http://snag.gy/0wA5i.jpg
    At each frequency I adjusted the trimpot to achieve a 90 degree phase shift. I am just wondering what could be the cause of this distortion? Could I be running into bandwidth issues with the op amp I'm using? (OPA4137)
    Thanks for any help,
    Dan
  2. ramancini8
    Member
    Jul 18, 2012
    447
    119
    I am suprised that you can get any response at 100KHz because the 741 open loop gain is very low at that frequency. You need a higher frequency op amp for higher frequency operation. Try a TL081.
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    The used OPA4137 has a GBW that is comparable with the LM741 (1 Mhz).
    The suggested TL081 ,by ramancini8 ,has a GBW of 3 Mhz.
    If you want a better opamp than that you could take a look at the NE5532, wich has a GBW of 10 Mhz.
    Bertus
  4. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Or you can use an LMH6514 that has a 100 MHz BW.
    Or you can get higher frequency op amps.
