phase rotation
Discussion in 'General Electronics Chat' started by phillo, Jan 4, 2007.
  1. phillo
    Jan 4, 2007
    Will reverse rotation damage equipment or will it simply not work?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Your question is just a bit vague. Running a motor backwards is usually not harmful. What equipment?
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A ratchet and pawl will be severly damaged if you can succeed in rotating it backwards.
  4. rootboy
    Member
    Jan 4, 2007
    13
    I remember a punch press shearing its (rather large) bolts off and flinging them across the room because the rotation wasn't correct. It was rather dramatic...
    Like beenthere says, it depends on what you are trying to run backwards.
    However it certainly shouldn't hurt the motor itself to be run in a different direction.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    And there was a time when I forgot to engage a magnetic clamp on a surface grinder and flung my project 40 feet through the air and embedded it into a cinder block wall.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I won't mention the time I left a vsr drill in reverse and still made the hole through a piece of steel. The bit was a real pretty blue.
