Phase of RC circuits
Discussion in 'Homework Help' started by Schoppy, Jul 8, 2014.
  1. Schoppy
    Jul 7, 2014
    26
    Can anyone explain to me how to arrive at the differences for the phases for these two circuits? I'm assuming it has to do with the characteristic differences between the voltage across a resistor and a capacitor but I'm not quite recalling the actual rule. Thanks in advance guys.
  2. Schoppy
    Jul 7, 2014
    26
    I can solve for the frequency this way as well which is how I've been doing it but I guess I just don't know the math behind it.
  3. MrAl
    Distinguished Member
    Jun 17, 2014
    2,554
    515
    What do you mean you dont know the math behind it? If you did it already you must know the math right?
    You mean the math for the phase?
    A network can be broken down into one real and one imaginary part in the numerator and one in the denominator;
    (A+B*j)/(C*D*j)
    and this can be made into one complex number:
    a+b*j
    The phase shift is then:
    TH=atan2(imag,real)
    where
    real is the real part, and
    imag is the imaginary part, and
    atan2(y,x) is the two argument inverse tangent function.
    If you've had complex math already then you should be able to do this, if not then you'll need to learn a little complex math first, which isnt that hard to do.
  4. Schoppy
    Jul 7, 2014
    26
    Yea I'm just confused why in the first picture I have -tan^-1 etc but in the second picture I have 90°-tan^-1 etc. Where does the 90° come from?
  5. Schoppy
    Jul 7, 2014
    26
    It's because the first is a low pass filter but the second is a high pass filter, do not know why though.
  6. shteii01
    Feb 19, 2010
    3,500
    511
    Probably the s in numerator. First one does not have s in numerator. Second one does.
  7. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Just a note:
    \frac{1}{1-j}\cdot \frac{1-j}{1-j}=\frac{1}{2}\left(1-j\right)
    and not what you have in the 1st picture!
  8. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Ok, I'm not going to tell you the reason directly but I'll try to point you there.
    s = jω
    A complex number (Z below) has an absolute value (or magnitude) and a phase (or angle).
    Z = a + bj, where 'a' is the real part and 'b' is the imaginary part!
    To find the magnitude we apply the absolute mathematical function to that Z number this way:
    \left| Z \right| = \sqrt{a^2 + b^2}
    and the phase is given by:
    \theta = \tan^{-1}\left(\frac{b}{a}\right)
    If you apply this to your case, you'll find the answer for the 90º.
    I assume that you know that when Z = \frac{a\pm b \cdot j}{c\pm d \cdot j} the phase comes \theta = \tan^{-1}\left (\pm \frac{b}{a} \right ) - \tan^{-1} \left (\pm \frac{d}{c} \right )
  9. MrAl
    Jun 17, 2014
    2,554
    515
    When you calculate the phase you have to do both the numerator and the denominator if you choose to keep the fractional form of the equation intact. When you have both the numerator N and the denominator D and wish to use the single argument inverse tangent function, the angle of the denominator subtracts from the angle of the numerator, so you must calculate two angles instead of one.
    With the low pass filter (the other picture) we dont have this problem because the numerator is purely real, and the angle for a purely real number is zero. So really we did the same thing, but the angle for the numerator was different in each case:
    Case1: 0-atan(x), angle of 0 degrees for the numerator
    Case2: 90-atan(x), angle of 90 degrees for the numerator
    If you choose to reduce the equation into a single complex number in the form of a+b*j, then you can do it this way:
    TH=atan2(b,a)
  10. PsySc0rpi0n
    Mar 4, 2014
    1,191
    I think his struggle is to understand where the 90 comes from!
  11. MrAl
    Jun 17, 2014
    2,554
    515
    Hi there,
    Didnt i explain that? It comes from finding the phase angle of the numerator.
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes you did, but maybe it didn't sink in.
  13. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Yes, I think that's it Papabravo...
    He's lacking some maths knowledge...
    But he is not replying here anyway!
    He needs to know the result of 1/0 and to analyse the trigonometric circle!
    I'm saying almost everything!
