Phase Margin Question
Discussion in 'Homework Help' started by jegues, Feb 8, 2014.
  1. jegues
    Sep 13, 2010
    735
    43
    For convenience I've attached both the question and my attempt at the solution. Please see figures attached.
    From the quadratic equation for the desired phase margin, I selected the w = 2.682 solution because I thought that we couldn't have negative values for w. (i.e. not physical)
    However the correct solution comes about when w = +1.491, but the solution to my equation indicates w = -1.491.
    How do we know when a negative frequency indicates an invalid solution, or a valid one where we can simply neglect the negative sign?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I believe it's a simple sign error in your equations:
    You have
    -130^o=-90^o-atan(\frac{\omega}{4-\omega^2})
    which then becomes
    -40^o=-atan(\frac{\omega}{4-\omega^2})
    then
    40^o=atan(\frac{\omega}{4-\omega^2})
    then
    tan(40^o)=(\frac{\omega}{4-\omega^2})
    and so on ....
