Phase Locked Loop
Discussion in 'Homework Help' started by Ashu93, Nov 16, 2012.
  1. Ashu93
    May 2, 2012
    My teachers told me that the output of PLL circuit is same as its input but i am not able to understand if the output of PLL is same as its input then why we are using it... Please help:confused::)
  2. MrChips
    Oct 2, 2009
    12,635
    3,453
    Well your teachers told you wrong. It depends on the context of the question and situation.
  3. crutschow
    Mar 14, 2008
    13,497
    3,373
    The output and input will be in phase but they have different frequencies. Thus you can generate an output frequency that is some multiple of the input frequency. If the input is from a crystal oscillator you can generate accurate output frequencies with the accuracy determined by the oscillator accuracy. That's how frequency synthesizers work.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Input and output can have the same frequency. As an example, a PLL with a VCXO can stabilize a jittery or noisy input signal.
  5. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  6. crutschow
    Mar 14, 2008
    13,497
    3,373
    I somehow figured someone would come up with an exception to my generality. ;)
  7. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    There is also a system that locks on any multiple of the reference, called the Huff and Puff VFO stabilization.
    Hans Summers has a couple of examples here:
    http://www.hanssummers.com/huffpuff.html
    Bertus
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, leave it to the old nitpicker.:D
  9. justtrying
    Mar 9, 2011
    329
    396
    I liked this tutorial when I tried to grasp PLLs.
