Phase Locked Loop Schematic Question
Tony Elliott
Joined May 8, 2015
158
pg: 8 fig: 13
http://www.ti.com/lit/an/snoa593b/snoa593b.pdf
I have been looking to build this circuit and on the schematic I looked at the optional (+N frequency to voltage divider), can anyone tell me what this is? And as it is optional what is its function as I want to use the circuit to convert frequency to voltage with a presition response time.
Anthony
Dodgydave
Joined Jun 22, 2012
11,301
Its optional extra, you can use a cd4017 decade counter or other ripple counter, there are other pll chips, CD4046, NE565.
ian field
Joined Oct 27, 2012
6,536
You would put a frequency divider chip (binary counter) there, if you wanted to measure frequencies lower than what the LM331 can operate at.
The 331 is equivalent to the Raytheon RC4151 - that may open up the search to a bigger resource of appnotes.
When a PLL is used for frequency conversion - a divider is used to put a divided down frequency on the phase comparator so the VCO has to go faster to keep up. That's the classic textbook example of using a divider to multiply frequency.
Tony Elliott
Joined May 8, 2015
158
So this can be used to translate the vco's frequency (with optionional outputs from s1 to s10 on the 4017) to the readable frequency limit of the lm311.
And I noticed fig 14 (pg9) on the original schematic improves frequency range.
