phase failure
Discussion in 'The Projects Forum' started by ADETIBA, May 2, 2012.
  1. ADETIBA
    May 2, 2012
    5
    I have a 30kva generator which as being working fine. but of sudden, there is no voltage in the red phase. if i connect the breaker to it, the neutral will be reading as life. what can be the course. house help out.
  2. rfredel
    Jan 23, 2011
    25
    is this a 3 phase generator?
    Can you measure the resistance of this faulty winding against the neutral and then compare the resisitance of the other phases to the neutral.
    I think, there a winding interruption is in the red phase, maybe a broken wire.
    Regards
    Rainer
    PS.: Sorry if my English is not so good.
  3. ADETIBA
    May 2, 2012
    5
    THANK YOU . The problem has been resolved. it was actually a broken wire
  4. ADETIBA
    May 2, 2012
    5
    THANK YOU . The problem has been resolved. it was actually a broken wire. the armoured cable was replaced and the generator started working fine.
