Any advice appreciated.
Over a year ago completed the mains supplies for 3 wind turbines.
Scottish Power meter head 3 Phase comes into a 3 phase meter. Then from that a 3 ph mains supply into a Triple Pole and Neutral Board.
From the board each of the wind turbines are supplied by a separate 63amp TP mcb. This goes to a separate isolator for each turbine.
The Turbine installers informed me that there is a problem with one of the phases.
Checked out. When all the isloators are off to supply the turbines I get the correct voltage across each ph and to N and earth..
Between Ph and Neutral I get 244 volts. As soon as I turn on any of the isolators for the turbines the middle phase drops down to 190 volts and causes all sorts of probems.
Any ideas what could be causing this..
