Phase Controller
Discussion in 'Homework Help' started by adimas33, Feb 16, 2012.
  1. adimas33
    Feb 16, 2012
    hi all.
    i want to build a Phase controller.
    i've search the circuit in google. but when i tried to simulate in Multisim 11 (NI, workbench) the circuit wont work??
    the main purpose of the circuit, is to controll the power transfered to the load
    example : control the heat element
    any hint how to make a phase controller? or do sombody have the circuit?
    Ac source : 220V, 50hz
    Load : about 300kw
    thanks for your attention
  2. jimkeith
    Oct 26, 2011
    539
    99
  3. adimas33
    Feb 16, 2012
    thanks to your reply
    yes i'd like to use TRIAC.
    but when im trying to make an RC triggering TRIAC. somehow i can't fire it freely from 0° - 180°
    and other option i had is by using external dc source for triggering. but i confuse how to make an zero crossover checking so i can made an delay to fire the triac based on zero cross over...
    do you have any circuit like that?
  4. jimkeith
    Oct 26, 2011
    539
    99
    for a 150A load???
  5. adimas33
    Feb 16, 2012
    no...
    im about to control 3kW LOAD
    then based on P= V*I
    so it's 13.6
    i think TRIAC still can handle this.
    umm.. do you have any idea.. how to detec zero crossover ??
  6. Felo
    Member
    Feb 20, 2012
    91
    13
    I have made a circuit like this to load and test a 3 phase UPS, around a pic 16f886 worked like a charm.
    The way to solve the cero crossing, (at least how I did it) was to take some simple and cheap opto-coupler, put a 4007 diode in series with one phase, a BIG ceramic 10w resistor and the the anode of the led in the opto, the cathode went strainght to neutral.
    This will give you a pseudo square wave wich you can work with, feed this to the input pins of your favorite MCU then...........do the rest. Hope this is helpfull
    Good luck
