phase angle of parallel RL ckt
Discussion in 'Homework Help' started by ria, Aug 19, 2011.
  1. ria
    Aug 19, 2011
    What is the magnitude of the phase angle of a 24 Vac parallel RL circuit when R = 45 [​IMG] and XL = 1100 [​IMG]?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I guess you want the phase relationship between the applied voltage and the current drawn by the parallel load. Work out the equivalent parallel complex impedance which (in the polar form) will have an angle component. The current phase will lag the applied voltage phase by the aforementioned impedance angle.
  3. scieng
    Aug 17, 2011
    If we are talking pure inductance, which doesnt really exsist then the current would lag the voltage by 90 degs, if its a real coil with resistance, then use Tan-1 of xl/r, so whatever xl divided r equlas, take the inverse tan of that number to give you the phase angle, this is will tell you how many degrees the current lags the voltage by. Hope I helped.
  4. scieng
    Aug 17, 2011
    my answer was for a seriers rl circuit, sorry mis read the question haha
