Phase and amplitude spectrum
Discussion in 'Homework Help' started by xxxyyyba, Sep 29, 2014.
  1. xxxyyyba
    Aug 7, 2012
    249
    Hi!
    I want to find phase and amplitude spectrum of this signal:
    Here is what I have done:
    f(t)=\sum_{-\infty}^{+\infty}Fne^{jnwt}, Fn=\frac{1}{T}\int_{0}^{T}f(t)e^{-jnwt}dt=\frac{1}{T}\int_{t1}^{t1+\tau}Ee^{-jnwt}dt=...=\frac{E}{T}\frac{1}{jnw}e^{-jnwt1}(1-e^{-jnw\tau})=\frac{E}{T}\frac{1}{jnw}e^{-jnwt1}e^{jnw\frac{\tau}{2}}(\frac{e^{jnw\frac{\tau}{2}}-e^{-jnw\frac{\tau}{2}}}{2})*2=\frac{2E}{Tjnw}e^{-jnw(t1+\frac{\tau}{2})}\sin{(nw\frac{\tau}{2})}
    I stuck there :( What should I do next?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Is the signal actually periodic in T? Does the picture indicate a single cycle of a periodic pulse train or do you require the Fourier transform of just the single pulse?
  3. xxxyyyba
    Aug 7, 2012
    249
    It's periodic...
    Here is amplitude spectrum:
    |Fn|=E\frac{\tau}{T}|\frac{\sin{nw\frac{\tau}{2}}}{nw\frac{\tau}{2}}|
    I have no idea how to derive it from my expression in first post :(
  4. xxxyyyba
    Aug 7, 2012
    249
    Forgot to write that tau=T/3.5
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    If f(t) is given as you have it
    f(t)=\frac{2E}{jn \omega T}\sin(n \omega \frac{\tau}{2})e^{-jn \omega \( t_1+\frac{\tau}{2}\)}
    To obtain the magnitude we can recall the magnitude of the exponential part is always unity - it simply imposes a phase shift of \text{-n\omega (t_1 +\frac{\tau}{2}) } radians. Also recall the complex operator in the function denominator also has no effect on the magnitude - it simply imposes a negative 90 degree value to the overall phase shift.
    So the magnitude then boils down to
    \|f(t) \|= \| \frac{2E}{n \omega T}sin(n \omega \frac{\tau}{2}) \|
    If we multiply both numerator and denominator of the fractional part by
    \text{\frac{\tau}{2}}
    We obtain ...
    \|f(t) \|= \| \frac{2E\frac{\tau}{2}}{n \omega T \frac{\tau}{2}}sin(n \omega \frac{\tau}{2}) \|
    Which can be re-arranged to the form you posted earlier.
    xxxyyyba likes this.
