PFC boost in SMPS
Discussion in 'General Electronics Chat' started by kni, Mar 6, 2012.
  1. kni
    Jul 20, 2011
    I try to adjust PFC boost(85 - 264Vac to 400Vdc) in switching mode power supply. my current design set output to 360Vdc then I set the voltage higher about 400Vdc and found power factor increase a bit(from 0.92 to 0.96) so I would like to know the relationship between PF and Vinac,load or else. Do you have equation to explain on this relationship?
  2. R!f@@
    Apr 2, 2009
    8,793
    771
    Ur Current design ?
