It senses whether water is between them, conducting. DI water is an insulator, but water in the wild usually conducts quite well.What is the sensor ?
On a conventional 555 it is .7 volts, but that doesn't tell me the input resistance of pin 4 on a CMOS 555, or what the maximum reliable resistance to use for the pull up. I agree I could have done it this way (with other changes), but this is the way I choose to do it. My confidence is high this will work the first time, and will only need new batteries every 6months to a year.the Reset minimum voltage level is 1V, so anything above 1 V and the chip will run ok, below 1V it resets.
Isn't that backwards? When the electrodes are dry, you need it to sound the alert. It can't be zero power consumption when the electrodes are dry.I would turn on and off your circuit using MOS-FET. Use a very high value resistor to hold the FET off. Put the electrodes from battery + to the FET gate.
Doing it this way, the circuit draws absolutely no power when the electrodes are dry.
by Duane Benson
by Jake Hertz
by Aaron Carman
by Jake Hertz
