PERTAINING TO THREAD CLOSURE
Discussion in 'Feedback and Suggestions' started by b.shahvir, Mar 10, 2009.
  1. b.shahvir
    Thread Starter Active Member
    Jan 6, 2009
    444
    Dear Beenthere,
    :) Hi, I was appalled by the rather abrupt way in which the thread ‘Light up LED From AC 230v’ by Kuma.lk in the ‘General Electronics Chat’ section of this forum was ‘locked out’ pertaining to safety issues. I myself have used or handled several LED circuits directly powered by the 230VAC mains. In my opinion, a cautionary advice on electrical safety (like the one you had posted) would have sufficed……. rather than closing the entire thread.
    Besides, I think Kuma.lk would be mature enough not to thrust his precious appendages into the circuit when it’s all juiced up!
    P.S. Please do not misunderstand me. I do not intend to judge your decision or offend you in anyway whatsoever! It is my opinion as regards the same which I felt I should express.
    Thanks & Kind Regards,
    Shahvir
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The nature of these forums is extremely public. If we only dealt with members as individuals, we could assess each as to level of experience and provide guidance based on that. But, as we are public, we have to limit some topics due to the inherent level of danger.
    The middle paragraph of Rule 2 in the Terms and Conditions of AAC is the basis -
  3. KL7AJ
    Nov 4, 2008
    2,047
    295
    Based on this criteria, just about everything I've done as an electronics hobbyist should be permanently BANNED! :D
    A brief excerpt from my "Opus of Amateur Radio Knowledge and Lore". :)
    "....Let us now address each of these points in detail. Number one, electrocution, is a good place to start. Amateur Radio is an electrical hobby. Radio amateurs, for the most part (with a few notable exceptions), have bodies which are every bit as subject to the ill effects of electricity as other mortals. Fortunately, the modern ham shack is far safer in this regard than those of yore. Most modern, commercially made radios have nearly inaccessible sources of dangerous electrical currents. With the advent of low-voltage, solid state technology, you almost have to work at getting a lethal jolt.
    Contrast this with the typical radio shack of half a century ago, which consisted of a loose collection of extremely high-voltage components lashed together with uninsulated jumper cables, sitting on the edge of a water-soaked desk, all powered by a distribution panel populated entirely with glass “fuses” bypassed with corroded copper pennies, and operated by a pre-teen boy sitting on a steel folding chair donning nothing but damp swimming trunks.
    It really is amazing that anyone survived the hobby at all. But here we are...."
  4. b.shahvir
    Jan 6, 2009
    444
    ;) Classic example of NO PAIN, NO GAIN....... i have got zapped so many times pursuing my hobbies that i have practically lost count!
    :rolleyes: I think some risks are in-evident and a part of the learning process.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That may be the case, but working with non-isolated line voltage is an aviodable danger. That carries a very real risk of death.
  6. b.shahvir
    Jan 6, 2009
    444
    I understand your concern for public safety....... i am with you on this! :)
