Persistence of vision Project
Discussion in 'The Projects Forum' started by Ricozb, Jul 5, 2011.
  1. Ricozb
    Jul 5, 2011
    6
    Hey guys,
    i am currently working on a persistence of vision project using the PICkit3 demo board. i have done all the code and wish to transfer it to another board but i am not sure how to create my own board, so i am hoping that someone can help me with it. i need a schematic of Pic18F45k20 with 8 LED, a toggle switch, 2 push button and a battery for power source
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    No clues on what pins/ports get connected to what?
  3. Ricozb
    Jul 5, 2011
    6
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Are you going to use the 40-pin DIP package, or one of the 44-pin surface mount uC's?
    You need to be specific about that.
    Cadsoft Eagle has a number of Microchip uC's in the library; not that particular uC, but the PIC18F4455 and PIC18F4550 have very similar pin layouts.
  5. Ricozb
    Jul 5, 2011
    6
    Oh, i didn't know that there were so many thing to consider but i will be using the 44 pin surface mount for my project.
    Do you have any recommendation for which pic is suitable for what i am trying to do?
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    If you developed your code for the PIC18F45k20, then moving it to something else will probably require a code change.
    There are two different 44-pin packages.
    44-lead plastic quad flat, no lead package (ML) - 8x8mm body [QFN]
    44-lead plastic thin quad flatpack (PT) - 10x10x1mm body, 2.00mm [TQFP]
    You're wanting the TQFP package, I suppose?
    Are you going to use 5mm LEDs, 3mm LEDs, or surface mount of some size?
    Are you going to use surface mount or thru-hole resistors? What size?
    Are you going to use tactile switches that are surface mount?
    Really need more info here.
  7. Ricozb
    Jul 5, 2011
    6
    sorry i am new at this.
    I will be using TQFP and 3mm LEDs.
    For the resistor i will be using Carbon Film Resistors (not sure how much ohmz yet) & for switches i will be using surface mount tactile switches.
    For power supply i would most likely be using Sony CR2032 http://www.sony.net/Products/MicroBattery/cr/cr2032.pdf
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    What IS your POV project? Is this one of those prop clocks? Or does the shape/size of the PCB not really matter?
    Anyway, I started to throw a schematic together for you, but there are just too many unknowns, so I'll just show you what I started and you can finish it.
    There isn't a battery holder for the CR2032 in the library that I know of, so I just threw in a different battery for now. If you find a battery holder for the CR2032, you'll probably need to make a layout and symbol for it.
    The .sch file is a Cadsoft Eagle schematic.
    You can download Eagle for free here:
    http://www.cadsoftusa.com/downloads/
    There is a good tutorial on Eagle over at sparkfun, here:
    http://www.sparkfun.com/tutorials/108
    Ricozb likes this.
  9. Ricozb
    Jul 5, 2011
    6
    it is just a simple PoV display tool, the PCB shape doesn't matter
    Thanks for the help
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    If this is your first PCB, you should consider starting off with something a bit less complex. That PIC18F45k20 has a lot of pins to solder down, and the routing might get a bit tough to do on a single-layer home-made board.
  11. Ricozb
    Jul 5, 2011
    6
    yup this is my 1st PCB project, i will take a look at other PIC and see if there is anything else more suitable for me
