Permeability and inductance?
Discussion in 'The Projects Forum' started by electronice123, May 9, 2009.
  1. electronice123
    Thread Starter Senior Member
    Oct 10, 2008
    304
    If I have an air cored inductor which has an inductance of 100mH, and I insert a core with a permeability of 5000, what will my inductance be?
    I know the inductance depends on a variety of things, but I'm just looking for a ball park figure (basic way) of estimating inductance whena core of a certain permeability is inserted into an air core inductor.
  2. eblc1388
    Nov 28, 2008
    1,542
    102
    Since inductance is directly proportional to the relative permeability of the core, I would say your new inductor should now have 5,000 times the inductance of the air-cored value.
    However, note the following from Wiki about the permeability w.r.t. current.
  3. studiot
    Nov 9, 2007
    5,005
    515
    Only true for 'close wound' components. That means the core has to pull the majority of flux into itself.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Also, the core has to have the same diameter as the coil's diameter to say that the inductance will be multiplied by about 5000.
  5. DickCappels
    Aug 21, 2008
    2,774
    671
    That only works in closed or learly closed magnetic loops (a gapless core like a toroid is one example). The actual inductance is greatly affected by magnetic path length and core cross section as well as the permeability of the core.
    The answer to your question is "Higher."
  6. KL7AJ
    Nov 4, 2008
    2,047
    295
    This is actually a very good answer. :)
    I might add that inductors that change permeability with current are NON-linear devices (saturable reactors). This property can be either HIGHLY undesirable, as in R.F. linear amplifiers, or quite useful, as in magnetic amplifiers.
    In most R.F. applications, special care is taken to AVOID operating the core in the non linear region....the transmission line transformer is just one such application.
    Eric
