Hi!
I'm looking for (and without finding) some kind of permanent circuit board, where you can make your own circuit with wires and flat circuits directly on the plate.
I know about pcb, but I understand you need chemicals and such? Is there any kind of plate where you can just cut out/attach circuits on a board? (so basicaly pcb without chemicals?)
-EDIT-
I will be able to do soldering, and drill own holes for wires on the circuit.
-EDIT2-
Is buying a simple plate of a resistant material a good idea? Like acrylic plastic? And then drill holes for wires and solder them on? But some way of making flat wires too is needed...
Thanks!
-EDIT-
-EDIT2-
Thanks!
