Period and Aliasing Problems
Discussion in 'Homework Help' started by josh007, Jul 4, 2016.
  1. josh007
    Sep 20, 2015
    40
    Good day All,
    I need your valued precious advice and help once again, in correcting my tutorial homework examples.
    Please can you check my work if I am correct or advice where I am going wrong.
    gracias
    Q1)
    If the signal x(t)=4cos(200πt) is sampled at 500 Hz, determine the signal x(n).
    What is the period of the sampled signal?
    MY ANSWER:
    x(t)=4cos((200/500)πt)
    so my signal x(n) = 4cos((2/5)πt)
    P = 2π/w
    Where w is the angular velocity = 2π/5
    P = 2π/(2π/5) = 5 units
    So Period is 5 units
    Q2)
    Determine the minimum sampling rate to avoid aliasing for the signal x(t)=20cos(400πt)+10cos(20πt).
    MY ANSWER:
    I will take the highest frequency to avoid aliasing.
    So P = 2π/w = 2π/400π = 1/200
    Therefore f= 1/T = 1/(1/200) = 200hz
    To avoid aliasing fx2 = 400hz
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    Looks good, except that sampling rates should not be given in Hz (though they often are), since 1 Hz is one cycle per second. Instead, the units should be Sa/s (samples per second).
    josh007 likes this.
  3. josh007
    Sep 20, 2015
    40
    Fantastic, much appreciation WBahn, I will take note of this. You are correct I read in my text book about the Sa/s but completely forgot about it.
    Gracias
  4. crutschow
    Mar 14, 2008
    13,488
    3,372
    So I think it's okay to refer to a sample rate as a sample frequency in Hertz. :)
  5. DickCappels
    Aug 21, 2008
    2,768
    669
    Alternative definitions are in common use. e.g.: What is the spatial frequency of this bar pattern?
  6. WBahn
    Mar 31, 2012
    18,085
    4,917
    I'd use either bars/inch (or other spatial dimension) or bars/pixel.
