Perfboard - Would you do any different from this?
Discussion in 'General Electronics Chat' started by atferrari, May 4, 2009.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,663
    784
    After an initial check with a breadboard and to get mechanical stability I am using the perfboard shown to properly test a circuit.
    As far as I can, I run all the jumpers first and then I start to populate by sections in the order they will be tested as shown in the other picture.
    Given the layout, would you do any different from what I do? I am basically asking if you think that it could be improved or what options you see, always using this kind of perfboard.
    Gracias for any ideas.
  2. Bernard
    Aug 7, 2008
    4,237
    414
    Looks neat and organized, better than I do.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Like was replied on the other site:
    There are way too many jumpers!
    Since you can't buy ordinary Veroboard or a good copy of it then your circuit with wires all over the place is doomed.
    For many years I used British genuine fiberglass Veroboard. It became hard to find then I found an excellent Chinese copy. It was discontinued then I found a Taiwan copy.
    The copies are called "stripboard".
  4. KL7AJ
    Nov 4, 2008
    2,043
    292
    If having wires "all over the place" is "doomed" I've been successfully operating doomed circuits for 45 years!
    Eric
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    My Veroboard projects do not have wires all over the place. They are wired neat and tidy.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Mine aren't, and they work just fine. Lately I've been doing it this way.
