Perfboard Construction with Insulation/Potting
Discussion in 'General Electronics Chat' started by tracecom, May 14, 2010.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,879
    1,396
    I am building a small circuit on perfboard. After it is completed and tested, I am thinking of coating the bottom side (wires, pads, solder, etc.) with rubber cement in order to provide some mechanical protection as well as electrical insulation.
    Good idea or not? Is there a better choice? How about some of this stuff used to dip tool handles in; would that work?
    Has anyone actually done this and how did it turn out?
  2. t06afre
    May 11, 2009
    5,939
    1,222
    I think it would be better to mount it proper in some sort of electronic housing. And also mount all cables going in and out with proper strain relief.
    You can get cheap plastic housing in most electronic stores
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    anything non-conductive will work really. Assuming no parts get hot enough to damage the coating. Rubber cement is flammable.. (I think they actually coat people with it to do the flamming man stuff in movies,etc..)
    But a protective box/enclosure with standoffs,etc.. is a better idea
  4. kingdano
    Member
    Apr 14, 2010
    377
    19
    a cheap plastic project box is a good way to go.
    if you want to pot it for some other reason, anything non-conductive is fine - use hot glue if you like.
  5. jamjes
    Member
    May 10, 2010
    35
    I've been using whitetack (like bluetack) to support the board, and epoxy resin the whole thing into the box. You can leave the whitetack in and resin it too, or try to be neat and remove it after.
  6. retched
    Dec 5, 2009
    5,201
    313
    Depending on the size of the board, and if you have to access it in the future, a resin cast is quick and easy. Window caulking works well and is cheap at home depot.. And you can remove it..if you HAD to. It MUST cure fully before you apply power.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Ask yourself this question, what are the odds I will have to work on the circuit again, either to repair or to modify it. If you think it is easy to build then potting it is an excellent idea, however, if you ever want to see those components again mount it in a box. There are situations where both are good ideas, potting definitely gives the circuit better environmental protection.
