percentage gain for op-amps
Discussion in 'Homework Help' started by lemon, Mar 14, 2010.
  1. lemon
    Jan 28, 2010
    125
    Hi:
    I am trying to calculate the percentage error for an inverting and non-inverting op-amp.
    For the inverting op-amp the error is 0.7V. This is the difference between the theoretical gain -Rf/Rin=100k/10k=10, and measured gain Vout/Vin=16.6/0.2=9.3
    error is 0.7V.
    Percentage error = 18.6/2 =9.3
    0.7/18.6x100=3.8%
    0.7/2x100=35%
    3.8%+35%=38.8%
    0.338x9.3=3.1V
    For the non-inverting op-amp the error is 0.1V.
    Percentage error = 3.80/2 =1.9
    0.1/3.8x100=0.03%
    0.1/2x100=0.05%
    0.03%+0.05%=0.08%
    0.0008x1.9=0.0015V
    Have I done this right?
    thank you
  2. Bychon
    Member
    Mar 12, 2010
    469
    41
    16.6/0.2 = 83 not 9.3
    I think you meant 16.6/2.0 = 8.3
    The calculated voltage output is 20
    The real voltage result is 16.6
    16.6/20 x 100 = 83%
    100-83 = 17% error
    for 18.6/2 = 9.3 demonstrated gain
    10 is calculated gain
    9.3/10 x 100 = 93%
    The error is 7%
    That's the end. The error is 7%
    Then you divided the voltage error by the real output voltage
    Then you divided the voltage error by the input voltage
    Then you added them together
    Then you multiplied that sum by the wrong answer from the first paragraph
    and you did it all without labels!
    Then you declared .1 volt error for the non-inverting amp
    Then you divided 3.80 somethings by the 2 volts you amplified
    Then you divided the declared .1 volt error by the 3.8 somethings and rounded off 2.63 to 3 and wrote it down as .03%
    Then you divided the declared voltage error by the 2 volts you were amplifying and wrote 5 as .05%
    then you added the last two wrong answers together
    then you multiplied a percentage by the answer to 3.8 somethings divided by the 2 volts you were amplifying
    and rounded off .00152 to .0015 volts
    Not even close.
