Hi everyone,
I'm building a small environment chamber for testing of a small PCB over a temperature range. I'm hoping for a -20C to 100C range and to be able to sweep this range over a 24 hour period.
I bought two 75W peltiers from digikey that ideally create a 69C differential and a water cooling kit for a PC. I want to run these in parallel in order to increase the cooling/heating power of the unit. I tested a single module in open air and was able to pull -25C to 100C from ambient (24C). I'm planning on using mineral oil in the chamber to keep the heat even across the PCB and to couple it well with the peltiers, which are dipped in a small aluminum heatsink.
I'm trying to figure out the enclosure design. The inside area needs to be 6"x6"x3". I bought some styrofoam containers, but I don't really like them from a structural point of view. I read that polypropylene and teflon have very low thermal conductivity, which seem like the way to go. Should I wrap the interior of the chamber with aluminum foil? Can someone recommend a way to do this or have any advice?
I already did all of the electronics with a simple 16A h-bridge with PWM interfaced with the computer, so I am not worried about this part of it.
Steve
Steve
