Hi all,
I have a peltier tile 30mm x 30mm, a heatsink, cooling fan and metal plate. So basically a plate that will heat up or get cool depends the direction of polarity.
I bought it with a USB end on it, but I want to install it in my car. So a couple of questions -
Firstly, is it ok to put 12v to the fan and tile? Or do I need to get a regulator to bring it down to 5v? Would the voltage have to be limited for the fan and/or the tile?
If Im not limited by the tile, does more voltage = a greater cooling effect?
Thanks in advance!
Thanks in advance!
