Hi to everybody. I need to control a peltier cooler of 17 W and with 2A of current. My circuit is this one:
(The voltage regulator is not the lm1084 but the lt1084). It works, but now I would like to use a h bridge to exploit the peltier both for cooling and heating.The problem is that i wanted to use a chip and i don't want to design the h bridge from myself but i didn't find any chip able to provide a 2A. So first of all, what do you think about my circuit(basically i need to add the capacitors for the power supply)? second, can you suggest my some h bridge for my application? (this is the first time that i use a peltier cooler) thank you very much
