peavey cs800s repair...
Discussion in 'The Projects Forum' started by kam-22, Jun 24, 2012.
  1. kam-22
    Nov 21, 2011
    19
    This old amp came in last week and it's main fault was powering up followed by fast turning fans and one channel led on:confused:..
    The thing about these amps is, it's a smp amp and uses a very complex power supply circuit lay out.. many years ago I serviced these amps and after checking my notes found the remedy...
    So after a strip down and check the o/p's all was well there next straight to the low voltage rail's again all good. time to rethink here as it still was doing the same thing..then on rechecking around the o/p stage it turned out to be the thermal resistors connected within it's main heatsinks these are 1k thermals that aid tracking. these can be brought from peavey spares and after a solder in it was back in working order..:D
  2. kam-22
    Nov 21, 2011
    19
    These amps can do 1200w in bridge mode at 4 ohms use... there 600w per can at 2 ohms and 420w ish at 8 ohms use...
