Thanks. I'll try that.Just take the screen shot, paste into paint and save as jpg. If you want to be fancy, paste into IrFanView and adjust quality so that pics are not huge files.
Thanks.I might suggest .gif format instead of .jpg, if you can use that. GIF is really good for something with limited colors, and will give a small file size with no loss of resolution.
Thanks all. Okay PDF to PNG, or GIF. Most converters seem to do all these.+1 to .png, unless the picture must go to an antiquated site or operating system that doesn't recognize the format.
Hi. You can, if you use GNU-Linux, install Popper-Utils:I am looking for a PDF to JPG converter to convert schematics in PDF to JPG. Free is preferable. Some don't do lines very well.
Thanks, trying it.Hello,
An other option would be the GIMP:
http://www.gimp.org/
That can read the PDF and convert it to any graphic format as export.
Bertus
Yes I did. Watermarks normally don't bother me, if the software is for private use. On the other hand, if it's for a professional application, $29.00 dlls for a license doesn't sound too bad. I guess it all depends on the user's preferences.Hello,
@cmartinez , Did you read this?
The demo version allows you to try all available features of Universal Document Converter. There is no restriction or limitation except for the addition of a watermark on each output file.
There will be a branding on the output file as I see.
A license will cost you $29.
http://www.print-driver.com/order
Bertus
