PCM systems
Discussion in 'Homework Help' started by kuridak, Aug 11, 2010.
  1. kuridak
    Jul 19, 2010
    8
    Hello, can someone help me with this question?
    A PCM system has the following parameters: a maximum analogue input frequency of 4kHz, a maximum decoded voltage at the receiver of (plus minus)2.55 V, and a minimum dynamic range of 46dB. Determine the following: minimum sample rate, minimum number of bits used in the PCM code, resolution, and quantisation error.
