PCM and PWM circuits needed
Discussion in 'Homework Help' started by saraali, Dec 13, 2011.
  1. saraali
    Dec 13, 2011
    9
    hi ,
    i am new member and i need your help
    i need 2 mini circuit one for (pwm)and second for(pcm)
    i use multisim 10​
  2. tom66
    May 9, 2009
    2,613
    214
    You need to expand:
    PWM:
    - sample rate
    - input range
    - output amplitude
    PCM:
    - sample rate
    - resolution
    - input range
    - output amplitude
    Is this coursework?
  3. saraali
    Dec 13, 2011
    9
    my teacher dose not give me this information
    i need onley design
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have moved this thread where you are more likely to get the help you need.
    Before you can design anything you need to set design specs. It is part of the process.
    Refresh my memory please, what is PCM?
  5. saraali
    Dec 13, 2011
    9
    hi ,
    i need (pcm) circuit
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Please use your existing thread to ask questions. Multiple threads only confuse the issue.
    I have merged your two threads.
    I looked PCM up on Wikipedia.
    http://en.wikipedia.org/wiki/Pulse-code_modulation
    You will need to decide on byte size. Again, you need to provide the needed information first before anyone can help you.
    I have changed the title of your thread to give people more idea what is needed to help you.
    Have you read these out of the AAC eBook?
    Pulse Width Modulation
    Chapter 13: DIGITAL-ANALOG CONVERSION
