Hi Dave, I have made a Voltage Doubler Circuit and I get the following readings. Input 110 volts AC output 300 VDC.? I expected to get a much lower reading than 300 VDC. I am using the following 2 x Diodes IN 4007 and 2 x electrolytic capacitors 100 u - 450 volts. With my current setup the input is 234 VAC giving 212 VDC output. I need approx 212 volts to ensure my unit functions properly. Any suggestions.?Usually in atx psus, they're about 330-470 uF, at 450V dc
