1. Iodem_Asakura
    Thread Starter Senior Member
    Sep 14, 2004
    140
    Hi guys.
    I have a PCB design that i made in my computer. Now i want to print it and make a PCB with it.
    How shall i print it? Ink or Laser printer? What kind of paper must i use? How to transfer the design to the bakelite?
    Take in consideration that is very difficult for me to get photosensitive bakelite. So i must use normal bakelite and use normal products to remove the copper.
    Thanks for your help
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    you could have just drawn your circuit directly on the board, that could have save you the trouble. way back when the photosen was not yet available for me, i printed the computer designed foil trace on a thin film plastic used for silk screen printing. then have it cut out meticulously, then lay it on top of the board and spray paint it. voila! i now have it neat on the board ready for etching. :D
    moz
  3. Iodem_Asakura
    Sep 14, 2004
    140
    I don't want to draw the design directly on the board, 'cause i want it to look more professional. The method you describe is good but slow and tedious.
    I believe i saw before a method where you can print your design on some kind of paper and transfer the printed design to the board using heat. But i don't know how exactly to do it. I'd like to hear more suggests.
  4. shreyas_bhat
    Jul 26, 2004
    47
    Hi Iodem
    I would urge you to get a print out of your design on a transparency.
    Use presensitized PCB boards (they already have a photoresist masking layer and are readily available in electronic stores for ~$10).
    Next, place the transparency on top of the board and expose under white light or UV for say a minute.
    Most presensitized boards get developed in an alkali based developer (like sodium hydroxide).
    After developing, etch it in a ferric chloride solution for say an hour at 50 C.
    You should have a good quality PCB ready to experiment !!
    sb
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Use a mirror image of the circuit (very important).
    Use laser printer.
    Transfer the design directly onto the copper using an iron (clothing iron, not solder iron) on low or medium heat.
    Clean the design up using a "sharpie" marker.
    Etch.
  6. Garry
    Member
    Jul 1, 2005
    12
    How large is your desing? Considering the overall cost for material and work, going through some of the professional PCB services might be an option, plus will look a lot more professional, too ... also, you might even be able to reduce the PCB size by using double sided PCB (which isn't really that easy to do at home) ...
  7. Iodem_Asakura
    Sep 14, 2004
    140
    My design is really small. It's about 1.5 inch x 2.5 inch. I prefer to it in home, so i can learn.
  8. mozikluv
    Jan 22, 2004
    1,437
    are you going for a commercial scale? if not, what you are trying to do is not a financially viable approach. as i have said before why not draw it directly on the board. there are so many ways to do it neatly. the neatness of your board will largely depend on your etching skill. thin lines are hard to produce neatly if you are not adept in etching. ;)
