hi, I need to get some wire to interface my pushbutton switches (panel mount) to my PCB. The wire should be single core and will be soldered directly to the board. my drill holes are 36mil and I will use a drill to twist pair them.
what cable do you guys normally use for said task? I will be using RS, so if you have any product numbers that would be appreciated.
Many thanks
Many thanks
