PCB Transmission Traces For RFID Coil Antenna
Discussion in 'General Electronics Chat' started by PIC-User, Jan 16, 2016.
  1. PIC-User
    Sep 25, 2015
    25
    Hi. I need to run about 6" of transmission PCB traces for a 13.56MHz RFID coil antenna. What is the best recommended way to run these PCB traces? Is it better to place the traces side by side, or is it better to place the traces one on each side of the PCB board?
    Remember that this is for an RF, 13.56 MHz, application. Here, we have crosstalk, EM losses, etc.
    Thanks for your help.
  2. Lestraveled
    May 19, 2014
    1,957
    1,217
    The wave length of 13Mhz is 72 feet. So, I would try to make a resonate coil on the PCB. The larger the area the more effective it will be. Any ground planes should be removed under the coil. If you can't make it resonate, then spread it out as best as you can.
  3. PIC-User
    Sep 25, 2015
    25
    Lestraveled, thanks for your help. But, my question isn't regarding the antenna itself. My question is regarding the 6" of transmission traces needed to reach the coil antenna. Do you have any recommendations on how to run these traces?
  4. Lestraveled
    May 19, 2014
    1,957
    1,217
    Oh, sorry.
    OK, because the frequency is so low the traces never get a chance to act like a transmission line. An RF line will not exhibit characteristics of a transmission line until is approaches a quarter wave length. In this case that distance is 18 feet. So, just run them close to one another. Spacing is not critical.
