PCB trace
Discussion in 'General Electronics Chat' started by Dritech, Feb 14, 2014.
  1. Dritech
    Sep 21, 2011
    756
    5
    I am going to connect a capacitor between the positive trace and the ground trace (each trace is 10mm wide). Should I design the PCB as shown in figure 1 or as shown in figure 2?
  2. Kermit2
    Feb 5, 2010
    3,838
    961
    If there is no physical reason, such as clearance for another component, that would require the small indents be present on the pcb traces, then use the configuration shown in fig. 2.
    Dritech likes this.
  3. MrChips
    Oct 2, 2009
    12,623
    3,451
    Neither of the two.
    A power supply decoupling capacitor doesn't go across the power rails any where you please. It goes between the power and ground pins of the ICs.
    DerStrom8 likes this.
  4. Kermit2
    Feb 5, 2010
    3,838
    961
    decoupling?
    Where was that asked about? Is some part of this post missing for me?
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    This is correct. Put the cap as close as you possibly can to the pins on the IC, otherwise you can get a lot of interference and the cap will be completely useless.
  6. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the replies. The capacitor will be connected 3cm away an H-bridge IC. Should I connected closer to the IC or is 3cm fine? Unfortunately I am a bit restricted because of the IC heatsink.
    Also, apart from distance, which trace is the best option please?
  7. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Usually if you put a cap across the power buses it's for decoupling.
    3cm is quite far, you really want to keep it to a few mm if possible. If you can't have it that close, get it as close as you possibly can. And as mentioned before, if there's no specific reason for the notches in the traces, don't put them there. Use option #2.
  8. #12
    Nov 30, 2010
    16,663
    7,306
    You can split the capacitance for physical obstructions. The fastest part of the load change can be supplied with a .1 ceramic within a few millimeters of distance and the bulk capacitance can be a few dozen millimeters away.
    ps, do not notch the supply bus.
  9. Dritech
    Sep 21, 2011
    756
    5
    Is it practical to solder the capacitors on the bottom side of the PCB (with the pin pads of the H-bridge supply) ?
  10. GopherT
    Nov 23, 2012
    6,300
    4,020
    Close for an op amp or logic IC. I don't see the need to be so close on an H-Bridge. It is just a block of 4 independent MOSFETS in one package. As long as the gates are connected correctly, I have never seen a need for a ceramic cap on an H-Bridge chip. Just make your power traces wide enough. I don't put a cap next to a discrete mosfet, why on an HBridge?
