pcb scaling
Discussion in 'General Electronics Chat' started by ctwistedpair, Jun 21, 2013.
  1. ctwistedpair
    Jan 14, 2013
    25
    Hi all, I'm having a devil of a time scaling pcb's with my laser printer. The first and last pins on the dips line up, but not the ones in the middle. These are circuit boards from reliable online sources. Any suggestions?
  2. GopherT
    Nov 23, 2012
    6,312
    4,031
    Clean the rollers on your printer?
    Or, ask a friend to print (or take a PDF to a store like STAPLES).
    That will confirm the printer vs file have errors.
    ctwistedpair likes this.
  3. panic mode
    Oct 10, 2011
    1,328
    305
    can you post a picture?
  4. circuitfella11
    Member
    May 10, 2013
    56
    5
    it sounds like if you need the accuracy for the pins of the dip's, and errors on the middle pins, maybe its a problem with the resolution..gopherT's solution on pdf's are good..
  5. ErnieM
    Apr 24, 2011
    7,437
    1,626
    I have never seen a scale error that isn't constant across the entire print out, unless it is a roll printer and the roll got stuck.
    Are you sure both ICs have the exact same number of pins?
