PCB resistor and capacitor types
Discussion in 'General Electronics Chat' started by relicmarks, May 18, 2008.
  1. relicmarks
    Thread Starter Active Member
    Oct 13, 2006
    355
    I have a big problem from telling what kind of resistor material types and capacitor material types
    HOw do you tell if a resistor is a Carbon Film resistors or Metal Film resistors?
    I can't tell any difference at all from looking at them on different PCB devices
    so its hard for me to order which kinds, how would i tell please?
    Which brand names back in the days did Carbon Composition Resistors come from ? allen bradly and who else please
    The allen brady carbon composition resistors are easiy to tell because they always have a BROWN body color
    But i don't know who makes those carbon composition resistor that are TAN cream body color or a redish body color
  2. relicmarks
    Oct 13, 2006
    355
    Ceramic capacitors- look like a brownish/orangeish circle
    Polyester film cap- looks like a small yellow square box
    Polystyrene- looks like a coil inside always?
    Polypropylene- ?
    Silver Mica- look like a Redish square cap with a "dip" in the middle of it
    Mylar capacitors- ?
    Polycarbonate capacitors- ?
    Capacitors with color codes? they are Polyester capacitors right?
    Metalized Polyester film cap- look like a white square box
    Tantalum caps- look like a "tire drop" brown color
    Polyester = Mylar film
    Whats the difference between Polyester film VS Mylar film?
    Polystyrene is easily melted-
    Polystyrene capacitors can be damaged by heat when soldering (it melts the polystyrene!) so you should use a heat sink (such as a crocodile clip). Clip the heat sink to the lead between the capacitor and the joint.
    What type of capacitor material are these orange drops?
    http://www.tubeampdoctor.com/english-store/TAD-Sprague-Orange-Drop-c-35_80/
    What type of capcitor material are these Mustard capacitors?
    http://www.tubeampdoctor.com/index.php?cPath=35_109&osCsid=c05dac54a63a96d22ca8ab1c41042761
    They look like Polyester film cap to me
    Mullard Tropical Fish capacitors
    "tropical fish" are polyester film capacitors
  3. AlexR
    Jan 16, 2008
    735
    54
    So what's the question?????????????
    If you have a question ask it but do not ask a question and supply your own answer in the same post. It confuses people!
  4. relicmarks
    Oct 13, 2006
    355
    My question is i Can't NOT tell the differences between these types of capacitors or resistor material types
    I have a problem with the bill of materials , so how can i tell fromt he LOOKS or any tips how to tell the differences of these resistors or capacitors?
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    If you want to buy very old expensive 600V orange drop capacitors with a horrible plus and minus 20% (M) tolerance then go ahead and buy them before they are all gone.
    The same for old carbon composition resistors.
  6. relicmarks
    Oct 13, 2006
    355
    are orange drop capacitors cermanic? or polyester?
  7. nanovate
    Distinguished Member
    May 7, 2007
    665
    Look at:
    http://www.vishay.com/docs/42018/715p.pdf
    From above link:
    "Replicas of the authentic Film-to-Foil Alu/PE design of the 60s Mullard/Philips capacitors as used in famous british Amps of the 60s till mid 70s."
    -- looks like a metal film type with Polyethylene (PE) plastic.
  8. relicmarks
    Oct 13, 2006
    355
    So the Orange drops are Polypropylene Film Capacitors?
    The Mustard caps are Polyethylene ?
    Whats the difference between the orange drops VS Mustard caps is they both are Polyethylene caps?
  9. relicmarks
    Oct 13, 2006
    355
    Orange Drops are Polypropylene Film Capacitor not Metalized Polypropylene but the FILM
    There is 4 types of Polyproylene or Polyester
    1.) FOIL
    2.) FILM
    3.) Metalized
    4.) Mylar?
    Orange Drops either come Polypropylene or Polyester they have both kinds
    Bumblebee capacitors? What type of material are these? they have color codes on them too
    I think the Bumblebee capacitors are Paper-In-Oil ?
    Paper-In-Oil Bumblebee Capacitors
  10. nanovate
    May 7, 2007
    665
    Google is your friend. Look up tutorials on capacitor types and construction.
    Nope
    That's why they are "Bumblebee"
